sodium gluconate 98% min factory - Druckversion +- Trophy Forum (http://www.trophy-forum.de) +-- Forum: Veranstaltungen Events und Treffen (http://www.trophy-forum.de/forumdisplay.php?fid=6) +--- Forum: Veranstaltungen Termine. (http://www.trophy-forum.de/forumdisplay.php?fid=29) +--- Thema: sodium gluconate 98% min factory (/showthread.php?tid=3603) |
sodium gluconate 98% min factory - fangzhefang - 25.05.2018 Sodium Gluconate Molecular Formula: C6H11NaO7 Molecular Weight: 218.14 CAS: 527-07-1 EINECS: 208-407-7 Properties: easily soluble in water and insoluble in alcohol; saline taste. Main Specifications: ItemStandard code Appearance White or yellowish crystal powders Loss on drying, %0.3 max Assay, %98.0-102.0 pH (10% aqueous solution)6.2-7.8 Heavy metals ( Pb), mg/kg20 max Pb, mg/kg 10 max Arsenic salt (As), mg/kg3 max Reducing substances ( D- glucose), % 0.5max Total numbers of colony, CFU/g10000max Coliform bacteria, MPN/g3max Molds and yeasts, CFU/g 1000max Applications: Sodium gluconate in industry: 1. Because sodium gluconate has excellent effects of corrosion and scale proof, it is widely used as water quality stabilizer, such as the treatment chemicals in the cooling cycle system in petrochemical field, low pressure boilerandengine cooling water system. 2. Steel surface cleaning agent. 3. Glass bottle exclusive cleaning agent 4. As a water reducer and retarder in construction industry 5. Used in the textile industry as a nuisanceless greenchelating dispersant Sodium gluconate in food: It is an important food additive,has a wide prospects for application in food. As nutrition supplements, food preservatives, quality improver, etc. There are a wide range of applications. Package: 25kg/bag, 1000kg/bag or as customers' request. Storage: Kept in dry and ventilating place, prevent from rain and moisture when storage; if agglomerated, please crush and make it into solution, and its effect will be the same. Shipping: Transportation:non-toxic, harmless, non-inflammable and non-explosive chemicals, it can be transported in truck and train. Our company is well acknowledged as one of the leading customized sodium gluconate 527-07-1 food grade nutritional supplements manufacturers and suppliers in China, offering the quotation consultation. All of our products are made under strict quality control and management system. Please be free to buy the product made in China with us.sodium gluconate 98% min factory website:http://www.baishengbiotech.com/sodium-gluconate/food-grade-sodium-gluconate/ |
